Most lancers I’ve seen are brutally kept so one should mentally and financially be prepared to spend up to 2-3 lacs in getting its old worn out parts replaced with genuine ones......these may include power steering hose, iacv motor, engine mountings, suspension bushings, front/rear shocks, rear springs, AC gas and service, rim polish, tire replacement, replacement of engine oil, transmission oil, brake oil, power steering oil and coolant, axle boots, rocker cover seal, spark plug seals, alternator bearings, possibly water pump, front brake pads, rear brake shoes, brake master cylinder or booster replacement, front brake discs, etc. When car is not properly maintained and starts giving work then there will be a LOT of big and small things being a nuisance. Above list is just to give an idea.
Better to spend more and get a car in good condition......unless you want a project car.
