AOA guys . I have recently bought a jdm alto 2017 model ... its driven around 34k km .. anything i should look out for or change?
Its r06a
I have ordered k-seal head gasket sealer. I will give it a try first and then will check compression.
What's the best LED lights replacement for the alto ...any recommendations??
@abdullahasifbajwa786 Which LED lights replacement you are referring? Lamp or bulbs? Kindly elaborate
Led bulbs
Check BI LED page on Facebook
Seniors please guide me, fuel average of Alto GII(upto 2009) or Alto G4(2010,2011) is same, what about 2012 to 2014.Any expert please tell me what is fuel average of GII, G4 and others. I want to buy suzuki alto 660cc.
Fog lamps installed
I am facing car jerking with check engine light and over heat sign.It appears when i start the car in morning and run it for a while. After running for some time, it becomes normal. Anyone can guide what could be issue before i take it to mechanic.
Is kixx cvtf okay for suzuki Alto eco ?
2013 2014 models have cvt mostly
How is it possible just share tipa
Aoaexperts please need helpmery pas alto jdm hai cvt transimmion 2015 model 129000 kmdriven. issue yeh hai k car jerk laiti hai after 40 aur 80 km/h aur long root pay almost 100 km chalny kbad jerks ziada ho jatay hain aur car drive krna mushkil hojata aur cvt ka sign ajata hai meter main lakin aik do din bd khud chala jata hai sign scan krwaya to yeh error show kia scanner nay p0841: transmission fluid pressure switch/ sensor issue. mechanic nay kaha is ka cvt gear change ho ga kisi. ay yeh issue face kia hai kindly sugest krain kia krna chaiye
Iam getting jerks too but no check light in my JDM 2014 alto. Change the transmission oil first with appropriate CVT oil probably CVT Green 2 and that see if there is any change. Otherwise just keep running the car and look for alternate CVT transmission. please let me know if you get any other solution to it.
where can i download owner manual of ALTO 2020 JDM, I just bought it and don't know anything about its maintenance, what oil should i use or what are the recommended filters etc. also is there any other community that is more active. like some facebook or whatsapp group etc.
Use Google translate and translate " Suzuki alto 2020 owners manual* to Japanese. Then copy paste that Japanese text to Google search. It will find you the Suzuki Japan website for downloading the manual.
Oil recommended is 0w20. Quantity is 2.6L with filter change. It uses all the same filters as of local assembled 660cc alto.
okay thanks i got the manual: https://www.suzuki.co.jp/car/owners_manual/files/2_99011-74P20_20201002112932.pdf and it says 0w 20 or 5w 30. I am going with 0w 20 as many sources on internet suggest the same.
Does anyone know how to operate Suzuki Alto HA25S audio system, picture attached below. I don't even know how to set a time. What are the other options available in this?
