I doubt the oil changed by them. Better avoid Suzuki Shinwari.
done 15k km still gng good 🏻🏻
still have to change trans fluid going for zic 75w90 , kindly suggest what to pour .
For ags suzuki 75wFor manual, 75w, 75w80,85,90 all are there
Aoa ... I am going to buy Suzuki Alto VXL AGS 2021. Any suggestions????
Never drive in 5th gear during break in period. Never drive in fix rpm or speed for long duration in this time.
Which engine oil grade & AGS transmission oil is pouring in VXL brand new by company?
10w-40 is recommended by suzuki...but many people are using 0w-4010w-40 is best for our environment
AOA sir from where did u get the fog lights work done from and how much was the cost
Mineral based 10w40 use in breakin period by company.
it a DIY did it myself cost was around 8k
Wow.. MashaAllah
you can search for alto 660cc fog lamps check that thread if you want to do it . not that difficult you just need to have some technical knowledge and will to do it .
Hi everyone..i am going to take delivery of alto vxr in few days..just wanted to ask some questions..do i have to get it maintained from suzuki like engine oil gear oil or i can use other brands?? Will it affect warranty? I am really confused about which oil should i use..thanks in advance
Dear... You will have to get it maintained from authorized suzuki dealer otherwise it will effect warranty
Ok thanks
Pak suzuki says that there is no need to break in the engine which is also called running..is it true? If thats not true then plz guide how to do break in properly..
Don't rev too high specially on low gears and use all the gears for first few hundred kilometers.
I am going to get VXL in a few days.
Kindly suggest
Shall be grateful
Do any one have expeeience of irridium spark plug in new alto???
