No paid Rs. 2000 for 0W20 as replacement of 0W 40 which was free of cost. However they said sir its not recommended and warranty will be void. But i took the chance as warranty normaly is not required if u are good till 5000 plus km moreover after running a few km who knows what grade oil it had, I guess
Alto and wagonr both don't have seat belt warning. Not sure about Cultus.
I am using 165/70r13 in both wagonr and Alto. This is the closest size to OEM size.
it's there
it's the best alternativeplease mention which ones you are using
Nankang remax tires., previously got dunlop eco in WagonR, it had very bad wet grip.
Not too many choices in this size. Pirreli or continental is avaliable but they are very expensive for the prize.
There is no buzzer. Only an icon in the instrument cluster which blinks when not wearing seat belt.
Why is there a WagonR sticker on the Alto vxr 🤦🏻♂️.. because both have same tyre profiles?
Anyways...pls recommend what pressure to be maintained to have a soft and efficient drive...36psi seems high and might make tyres hard and bumpy ride
recommended pressure by suzuki japan for 145/80R13 is 280 kpa, i.e 40 psi
This one year free maintenance offer is from Pak Suzuki, not from Azam motors.Moreover Azam motors is not in I-9.
Never give out wrong information or guidance. If you are not 110% sure about something. Its better to let somebody else answer.
buzzer is only for key and fog lights
from actual cultus, the one we had back in 2017-onwards, 2 things are different nowthere's no vanity mirror nowthe door fabric pattern on front doors is differentpreviously, this
Now
other than that, rest everything is same (headunit is added officially unlike other 2)
Cultus VXL.
Vanity mirror is present on the driving side of All cultus vxl. The chances of it missing are shockingly rare. If it has happened then it should be reported.
If it is being intentionally by Pak Suzuki then sharam se doob maray pak suzuki
yes it's no more there
these mat holding clips were in the mats shopper?though the clips are fixed in these carpet and body holes
which dealership?
Is installing JDM Alto rear seats an option?
Bad news for existing owners however one should always look for a silver lining.This step is most welcome as prices will go down as a domino effect
