i did it without striping any wire , simply remove the rear bumper take out the grip , mark the wire that is reverse using a pin take that pin out wrap the wire around it solder if you like push the pin back in and you are done 🏻🏻 and on the headunit side the reverse signal is a simple wire coming out you can strip that .
i also did the leveling lamps and by same way i used the connector to take the signal , if you want to remove you can simply take the pin out and disconnect it your wiring will return to oem , simple as that .
Wish I knew all this what u r talking about
Are you from Karachi? May be you can help me with this
how much registration charges taken by mandviwala? they confirmed me 20k.
nope bro i am from islmbd but sure can help you by sending the pictures of how its done .
i got another thread search by "alto 660cc fog lamps" on pakwheels forums everything is documented there do visit it will help
26k for ags vxl
Thanks bro. Sure will check it out
thats correct
19260 are for AGS registration and on top of it whatever they are charging is their commission.
I asked them to give me invoice is service charges. They agreed to 3000 as service charges. It was whatever the excise slip plus 3k
26k is too much. mandviwala themselves told me it's 20k.
@danishmmh bhai Karachi me kon kon se company operated Hascol pumps hain can you list?
19260 is too much as last month my new wagonR 1000cc is registered and excise slip is of 18k something. 660cc must be around 14-15k in actual
Is it of Punjab??as I got registered in Punjab and it costed 46k ...!!!!
Karachi (sindh)
Its 1% of invoice + other taxes.
I think cc doesn't matters. Paid 18000 something to bank in 2019 that included service charges.
They charged 20,000 returned excess amount.
Karachi. Sindh
Hmm that's what it is.
Left Hascol a year back, but currently two are direct property of Hascol. One on Shara e Faisal, adjacent to NHA. Other is port qasim. One more on Shara e Faisal and one in Malir cantt. Are prime dealerships.
Alhamdulillah booked my new alto yesterday. probable delivery date will be confirmed in a day or two by dealership. PO deposited. due to increasing rush in cities and rising fuel prices i believe Alto is the best choice for daily commute. so Inshallah i will be a part of this group very soon
