since start i am using 30 psi. the ride feels smooth and stable.
but as @ifadey mentioned, i can try at 33. lets see what happens
the fuel average for ags stays from 16-18 depending on Karachi peak traffic and normal foot. on empty roads it goeas to 22 easily. the max i have got from a full fuel tank is 428 kms with the light on.
I am using 33PSI and the car is going fine. mostly the car is on short runs and have ODO meter on 45k and with current average of 17.5
I have tried all the psi between 30 to 36 but car feels very underpower in 30 or 31 psi.. Suzuki company and their dealership has not clear statement about it. Suzuki company replied i have already mentioned above and about the dealers some says 30 psi and some says 36 psi . I just worried that 35 or 36 not ruin the suspension in karachi roads
My suzuki dealership fills to 33 psi by default
Which dealership?
Suzuki Racecourse Motors in Rawalpindi
33 psi worked best for me. I felt better braking and yes the car feels less bouncy on speedbreakers and pot holes.
wat is change interval of brake pads? front n back?
I guess its 40K?
Yup dealer told me same mileage when last visited a month ago
Rear drums can last twice as long as front disk brake pads
the car in question is 21k drive, no harsh or rash driving.
i see the brake fluid level going down, i know it goes down when the brake pads are worn out.
so shud a get it inspected or wat? there are no leaks etc
I also did a tour of islamabad from karachi with 2 adults and 2 children along with luggage and got following average:
16 kpl @ 120 kph20 kpl @ 100 kph
Next time try 36 psi tire pressure. You may get the same mileage. Also change your oil grade if you are using 10w-40.
I was using 36 psi in all tyres and using 10w-40. I don't think that shifting to 0w-20 will make big difference in mileage. In city driving i am getting 19 kpl average with light foot driving.
Try 5w-30 once and see the difference0w-20 make difference in short trips
Are u using completely manual mode?
Hi, brother it is still automated as even the manual works through actuators. But, yes I use manual mode all the time and use auto when I need to go fast as possible. This I do because of the excessive clutch engagement in 2nd gear particularly. Also I can change gears at the earliest giving me good mileage.
How many kilometers u have driven . And what about when using manual mode gear from 2 to 1 comes on very low speed approximately at 5 should i manual change to 1
How many kilometers u have driven. And what about wheb using in manual mode gear from 2 to 1 comes on very low speed approximately at 5 speed should i change it manually
