A break system which is not even considered enough to stop 1.0, what wonders will it do on 1.5? Else I don't think you would be able to use 1.5 at its potential. I don't know the fact just a suggest though. Compare Margala break system with cultus in size, are the both same in master cylinder, break caliper, etc, if same than you are right. I think PW encyclopedia can shed some light on that
Sent from my GT-I9505 using PW Forums mobile app
Let me discuss this with senior members
Ya sure, I also own same model cultus, clocked 4,75000, km, yap you read it right, :), origional engine, Alhamdulilah so far going strong MashAllah. Following your thread for future.
Actually boght this a year ago thats engine not well maintained but i will make it the way i want..
Sent from my SM-G900F
get a G10B or G15B-G13B is DOHC and its hard to find-G13BB is easily availabe but i wont recommend that-All G engines will be bolt on fix and the chassis can handle even a G16.Make sure that the engine you get is neat and clean along with the correct ECU,transmission and uncut wiring.if you wanna use the A/C then make sure that the electrician wires up the A/C with the ECU
Okay this is some good info i will make sure electrition connects ac with ecu
just a bump so that senior members can view it
I am selling my carby engine g10 kindly check in seller section under engine and isb city
After changing engine what other things i need to knw that should be checked or changed ?
waste of money & destruction of car, besides serious devaluation of engine changes vehicle. Instead seriously consider net total budget you have for 'MIGHTY rebuilt' plus car value. If thats' a substantial amount change to a better car
I will cost me around 100k for a complete setup if i keep my g10 carby Bro i want to change the engine no matter the consquences only matters is the power i want frm my car ...
if you are so adamant, I'd recommend Honeywell engine TFE 731-50R, do not forget to buy it matching ECU wiring & drive train to stay on ground. Good Luck
LOL if it can hold that thing i will try that as well
Can someone give me the number of maxtorque so i can get my engine installed peoperly If there are other garage that can swap engines perfectly including wirong stuff do give mw location and number
anyone ??
G16B installed very much happy with its performance as well as milage I recommend it to guys who want to swap to g15 or g16 It cost me around 115,000 in total i changed my whole suspension as well in this cost
Sent from my SM-G900F using Tapatalk
Would you like to share milage you are getting with G16?
I didnt check properly i guess it vary bw 13 to 15kmph
do post some pictures of the engine bay...
Where can I find digital flow meter to find km/l for a specific route.
