5W-30 is recommended by suzuki as well
i have owned manual in feb 2018. and AC is working well n issue.
dear this new shrt antena work?i visited a shop for purchasing it but shopkeeepr said it does nt work it is only for show. is it true. i too want to change long antena.
i have just bought Maguier NXT 2D Wax. it Result is very impressive.
yes it works but i will update you in few days as i am living bit outside of city and signals are weak in my area but still its working but i will give u my final views after few days when i will check properly .
I have order Maguier Ultimate Wax and couple of Formula 1 items
I bought this from Ali express as i didn't know i can use Swift one. I didn't play much with radio but still its working.
Got this Today will update after using this Camera
$ 40.11 Whole set from Aliexpress
Plus point is You don't need to cut any wire to attach back camera if you plug back camera it start giving you back view . As you know we cant do any electrical modifications as long as Car is under warranty. You can split the screen half half .
Whats the size of the rear view mirror?Does it come with a battery or one needs to connect it with the lighter charger at all times?And how much is its internal memory?
Yes i think it comes with battery for standby but didn't check properly as i check with Lighter Charger and after unplug it was still on .NO internal Memory you need to insert Memory card.
Screen size? Length x width?
Screen Size is 4.3 inch
They didn't forget to fill the gas. It leaked out.If someone is facing this issue in brand new car, believe me gas will again leak if he gets it refilled. Better check all joints for leaks.
