Shocks should be replaced or repaired in pairs never do single shock that could disturb the balance of your car....
And for that tuk tuk type of sound check suspension arm first....
Sent from my D2502 using PW Forums mobile app
Agreed with @hassantahir2Replace in set,not the single. Better try this brand product:Products | Agriauto
DO NOT go for used ones. In lahore KYB Malaysia are arnd 5200 a pair for new ones. Front only. Genuine are arnd 9000 a pair. Cant say how good KYB is but they work fine as i have KYB on my Reborn as well. Its a big international brand. Search it online.You probably need front shocks first confirm from your mechanic.
Sent from my LG-D850 using PW Forums mobile app
I had gone through the same problem and the problem diagnosed was suspension arm aka chimta. Got repaired and put new bush problem solved. You should also start inspecting with this might be u have same problem with your car. Regards
Sent from my LG-LU6200 using PW Forums mobile app
I have suzuki cultus 2001.Found some noise from axles n suspensions too.Does anyone know the best place in karachi to get it replaced with new one in reasonable price?IG motors charging 16k for axles only.
Plz share your opinion.
