Eps installation is fairly simple in cultus. It's an approximately 1 hour job. U need to replace the steering column only with ur eps column. Make sure the electrician does the proper wiring connections. Replacement part will cost u around 6 to 7k. It's a pretty much bolt on mod. U ll b needing eps of jdm alto for the retrofit
Sent from my SM-G900T3 using Tapatalk
