@ bilalahmad!
bro if it was lahore than i'd have helped u...but its rawalpindi..i think VAQAS bhai can help u..but here are phone number of lahoree showrooms...u can call their to get number of RWP showroom...
5163334-35 suzuki town ship
6365889-6375851 suzui bagh e jinnah
btw here are specs of GS 125 and GS 150 which i once SAVED from net when suzuki site was working.
SUZUKI GS 125:-
Engine Type 4 Stroke Air Cooled, OHC
Bore 57mm (2.24 in)
Stroke 48.8mm (1.921 in)
Compression ratio 9.3 : 1
Starter System Kick
Transmisson 5 Speed Constant Mesh
Overall length 1945mm (76.6 in)
Overall width 780mm (30.7 in)
Overall height 1035mm (40.7 in)
Wheelbase 1270mm (50 in)
Ground Clearance 170mm (6.7 in)
Dry Mass 115 KG
Tire front 2.75 -1B 42p
Tire rear 3.00 - 1B 47p
Fuel Tank 12 Litre
Drive Chain RK428 FDZ, 116 links
Battery 12v, 14.4KC
Front Suspention Telescopic, Coil Spring, Oil damped
Rear Suspention Swing arm, Coil Spring, Oil damped
Head Light 12V 35/35 W
Brake Light 12V 21/5 W
SUZUKI GS 150:-
SPECIFICATION
Bore 57mm (2.24 in)
Stroke 56.8mm (2.36 in)
Starter System Electric & kIck
Transmisson 5 Speed Constant mesh
Overall length 2005mm
Overall width 785mm
Overall height 1065mm
Wheelbase 1270mm
Ground Clearance 165mm
number of cylinders 1
Dry Mass 119KG
Tire front 2.75 -18 42p
Tire rear 3.00 - 18 47p
Fuel Tank 12 Litre (3.2/2.6 US imp gal)
Ignition type Electronic Ignition CDI
Battery 12v
Front Brake Drum Brake
Rear Brake Drum Brake
hope it will help many members in buying these bikes.
