Important update for Mehran users. if you car have following symptoms then do this as i have done with my car:
1) Stiff or hard steering while you turn from left to right either in standing or in driving position.
2) When u turn steering left and right, you hear sound of coil springs.
3) You can also feel the turning while putting your hands on the front shocker mounts and then turn the steering from left and right.
4) whenever you take a left turn or right turn, your car doesn't go in the straight direction.
I was having same issues, despite i have changed tires, changed some bushes and even done proper alignment. the steering was stiff than normal i feel pressure while moving the steering. The alignment wala provided me the solution to over come this issue.
He simply removed these pathetic plastic insulators used by PAK SUZKI
He simply replaced these insulators by opening up the front shockers and placed the ones "sample pics" which are in the pictures below.
these insulators were taken from alto vxr as per the mechanic. the inner ring moves while the outer rings remains stationary. this ring fits in hole of the mount cup. after fitting the result is the steering is smooth as silk, no spring noises and no sticking of springs.
