I am a bit confused about replacing the clutch, pressure plate and bearing kindly assist, currently the clutch is quite hard and makes noise when pressed I got it lubed and sprayed wd 40 on it for some time it was a bit soft but then again back to its original position.
Got it checked from dealership and local mechanics some say it does not needs replacement clutch of swift is hard whereas the others have told me to get it replaced, I tried testing it by applying some methods shown on youtube and as per those tests it is fine but the issue still remains, it is quite hard and makes noise and on top of that sometimes gears do get stuck and even if they don't still the shifting is not that smooth, what should I do kindly assist.
