@warlock
Gorgy Porgy pudding and pie kissed girls and made them cry. When the boys came out to play Gorgy Porgy ran away.
So now you run away at least you will not make wrong statements anymore.
To wrap things let me say the things in the right perspective.
You were advice to discuss matters base on facts instead you make stupid arguments.
Do you (micking) possess any recommendation letter from any car manufacturer? If yes post it on the net.
I said micking is a unqualified product , can you prove otherwise if yes post test results of micking oil in Pakistan on the net.
Micking buys base oil from other parties. The third party blenders like michang buy second and third cuts of base oil to reduce cost which help them sell product at lower cost such as micking. This reduces product performance. Base oil not produced in house results in Variable product production. Companies like shell, mobil and caltex produce their own base oil.
Your facts about products of Korea and market share is totally wrong. Micking and gorilla do not have even 1% share in the Korean market. Major players are SK ,Caltex , Mobil, S oil ,shell ,total, Fina elf. If you are not aware of a fact, please do not quote wrongly. Anyone having doubts may contact S korea embassy in islamabd for reconfirmation of share as mentioned here.
Your contention of mine not knowing blending is based on allegation. Do not try to hoodwink others. Ask an expert to visit michang (micking) site. You will be told that this is a run down plant.
They do not have any PLC control system, there is no pigging system in the plant, Packings are load system based, there is no mentioned of qualified labs with equipment. There is no R&D. It is at best equal to badami bagh blending plant in Lahore.
My request to you is please do not run away, Prove your facts. Don’t behave like a kid. If you are such a fan of micking then address those issues.
At the end I would want to repeat with emphasis.
Micking is an unqualified product. They have received only API certification four months back. Without any car or truck manufacturer recommendation .if used the car manufacturer is not going to extend their warranty. Using micking is dangerous, so do not use it.
In the end may I explain to my learned friend? API classification is only for guiding the user about the minimum level of motor oil. Most manufacturers have API approval. To become a qualified producer of motor oil, a blender should possess OEM recommendation. Micking oil does not possess this.
I talked with Hyundai people at Dewan motors, they were very clear that micking is not recommended by them. Hyundai recommends shell. So any one with Hyundai car should not use Micking. If the car engine goes down, Dewan motor will not provide its warranty.
