table align=center" cellpadding=0" cellspacing=0"tbody
@nomi1234.... these are specs of 404.... sad non in Pakistan
table bgcolor=#ffffff" cellpadding=0" cellspacing=0" width=125"
tbody
/tbody
/table
map
area coords=5,2,93,20" href=unimogfs.html" onmouseout=MM_swapImgRestore()" onmouseover=MM_swapImage('forsale','','pageimages/headerelements/blkforsaledwn.gif',1)" shape=rect"/area
/map
table cellpadding=0" cellspacing=0"
tbody
/tbody
/table
table cellpadding=2" cellspacing=0" width=118"
tbody
table cellpadding=6" cellspacing=0" width=100%"
tbody
/tbody
/table
/tbody
/table
table align=center" cellpadding=0" cellspacing=0" width=520"
tbody
h2
Model 404.1 Specs
/h2
Sales designation:404S
Later known as: U82/404 or U91/404
(depending on engine state of tune)
Dimensions:
table cellpadding=0" cellspacing=0" width=100%"
tbody
Width
2150 mm
84.6 in.
Length
5030 mm
198 in.
Height
2290 - 2650 mm
90 - 104 in.
Wheelbase
2900 mm
114.2 in.
Track
1630 mm
64.2 in.
Turning Radius
11.9 meters
39 ft.
Approach Angle
45 degrees
Departure Angle
46 degrees
Min Ground Clearance
400 mm
15.75 in.
Fording Depth
800 mm
32 in.
/tbody
/table
h3
Weights:
/h3
tbody
Curb Weight
2850 kg.
6383 lbs.
Gross Weight
5000 kg.
11,000 lbs.
Max. Payload
2150 kg.
4740 lbs.
/tbody
/table
Top Speed:
107 kph / 66.5 mph @4800 rpm
Engine
: Mercedes-Benz M 180
tbody
Type:
Gasoline (petrol), 7.0:1 Compression ratio
Displacement:
2195 cc / 138 cu in
Cylinders:
6
Power:
60kw / 82 Horsepower @4800 rpm
Max RPM:
5500
Ignition:
24 volt, Shielded
/tbody
/table
Axle Ratios:
table cellpadding=0" cellspacing=0" width=60%"
tbody
Ring and Pinion Ratio:
3.54
Hub Reduction Ratio:
2.13
Final Axle Ratio:
7.56
/tbody
/table
Transmission:
6 speed synchromesh transmission with 2 speed reverse. Internal transfer case providing rear wheel drive or 4x4. Additionally, there are mechanically locking differentials on both the rear and front axles. 4x4 and locking diffs are Shift on the fly .Ă
Ratios: Gearbox Ratio / Final Drive including Axle Ratio
tbody
1 st
14.93:1
113:1
2 nd
8.23:1
62:1
3 rd
4.47:1
34:1
4 th
2.47:1
19:1
5 th
1.53:
12:1
6 th
1.0:1
7.56:1
Reverse:
1 st
20.1:1
152:1
2nd
11.1:1
84:1
/tbody
/table
In addition, there is an optional 2 speed supplementary reduction gearbox which provides two addition ratios:
tbody
1 st
46:1
347:1
2 nd
25:1
192:1
/tbody
/table
In addition a front/rear PTO unit is available but not in combination with the supplementary low ratio gearbox.
Steering:
Recirculating ball, no power assist.
Brakes:
Hydraulic. (power assist on some applications.) Dual or single circuit depending on application.
Electrical:
24 volt 19 amp (300 watt) generator
Tires:
10.5R20 tires on 9x20 rims. 12.5 tires also fit.
h2
Model 404.0 Specs
/h2
Sales designation:
U082/404 or U110/404 depending on engine.
[highlight]
Dimensions:
[/highlight]Same as 404.
Engine:
M
ercedes Benz M 180 (U082/404) Same as 404.1
Optional: Mercedes M130 (U110/404)
tbody
Type:
M130 Gasoline (petrol), 7.8:1 Compression ratio
Displacement:
2748 cc / 170 cu in
Cylinders:
6
Power:
81 kw / 110 Horsepower @ 4800 rpm
Max RPM:
5500
Ignition:
24 volt, Shielded
/tbody
/table
Axles ratios:
Same as 404.1
Transmission:
Same as 404.
Steering:
Recirculating ball, power assist optional.
Brakes:
Hydraulic. (power assist on some applications.) Dual circuit.
Electrical:
24 volt
27 amp (750 watt) generator
Tires:
same as 404.1
/tbody
/table
table cellpadding=2" cellspacing=0" width=120"
tbody
tbody
/tbody
/table
/tbody
/table
/tbody
/table
map
area coords=6,4,141,19" href=unimogabout.html" onmouseout=MM_swapImgRestore()" onmouseover=MM_swapImage('aboutunimog','','pageimages/headerelements/blkaboutunimogsdwn.gif',1)" shape=rect"/area
/map
