hmm.. i got the figure in the book that i mentioned,,btw if u r getting a good response its ok,,variation is possible,, normally it should be from 1 to 3 full turns out,,whichever gives best response,, its not a fix value always,,
clutch box gone:(burnt clutch plates of 88. i over revd tooo much
Thanx for Sucha GOOD NEWS!@MODS Shoot him LolX.
idle mixture strength screw for RX115, with original carb and 17.5mm pilot jet and 21mm float height is 2.25 turns outwards. If the float height is not correct the factory adjustment wont work.
1.5 turns outwards is for YB100 - and also requires the float to be correct along with original sized pilot. (its also 17.5)
This screw only has an effect in performance from zero to 1/4 throttle.
jazakallah realy cleared my doubts with an excellant reason,,i only knew default settings wont work always but dont knew y,,thanks for clearing it,,
share the details of clutch work that will be done,,,
i have got hole in my pocket:P:P:Phave to save some bucks
@Xulfiqar,Well explained Bro.@hidalgo,Indeed. . . .
Thank God you are far away from my place.
Plus Chitrolll :P:P:P
ufffffelders these days:P:P:P
Hahaha.Here a an elder came for Ur chitrol.
hey guys lil updates on yamaha 88got it tunedcurrent fit ha its at .50 sleeved cylinder, local piston yamaha s orignal conecting rod, orignal carbbut there is a slight problem on high rpms bike lags baith jata ha simple words mawhat it could be?
^^Where are the pics? What about swingarm fault?
@r1sorry bro no pics:(and swingarm is nothing to worry about as per my mechaniche said minor sa dent ha
@r1bro no pics and as per mechanic that swingarm dent is nothing to worry about
What would be the color scheme of your new beast?
@r1most probebly gonna be red or black.have yet to decide.have to sort some engine problems .may be after eid the project starts
Good Luck . . . .!
nomi bro thread s in new look ur wish ma command:)
What about these..
YB 1981
YB 1989
