I have been looking into installing a solar setup in my home, but I have put it off for the time being because I would rather go with microinverters rather than a centralized DC inverter, although it would be more expensive, but the advantage is that you can start with a small setup and keep adding solar panels later. Installation is easier and it eliminates a lot of other parts that would be required with a conventional DC solar setup. Also individual output of every panel can be monitored and if output of one panel is low due to shading or some other reason, it does not affect the output of the entire setup.
Is there someone in Pakistan who is doing a solar setup with microinverters?
Secondly I am wondering why are you not using the inverter in grid tie mode, do you need special permissions from Lesco or is it for some other reason?
