hey
specially @nfssaad . you've answered me before so hope you can guide me further. Others too welcome !
I want to run under 2-3kw load. Any solar UPS that can give power in this priority:
-When solar available, use that to give output.
-When solar 800w available, but load is 1600w, use full 800w from solar, and remaining 800w from utility.
-When no solar/at night, use UTILITY to give power
-Lastly, when no utility+solar, only then use battery power (to save battery cycles n discharge).
-Use solar to charge batt, if no solar available(at night) then use utility to charge battery.
**Optionally, when I don't have any battery connected, it should be able to output from only solar or solar+utility too... but not required as I will mostly have a battery attached for backup...
Anything not too overpriced?
And what is this mode called in all the power/solar terminologies... ?
