Hi! So I bought a Prius PHV 2012 to mitigate, to some extent, the rising fuel prices. In Islamabad most of our trips are around 18-20 kms so I thought I'd be able to charge on return from say dropping kids to school, and repeat. 3-4 trips per day around 70-90 kms driven on average. My GLI was costing me at least 2000 rs per day, and that is for one car only. The driver is new to hybrid driving but I am still getting around 15 or so kms of only EV driving, which is good enough, as the ICE runs for only 3 or so kms doing 20+ km/l. This way I am getting the required KMs for only half a litre or so of petrol, Alhamdolillah. This changes slightly with occasional longer trips tho, when say on a 30 km trip, half the KMs are on regular Prius ICE HV mode.
Each charging takes 1.5 hrs and 3.3 units (10amps, 2200 watts) for Prius's battery capacity of 3.3 kW. Exact impact on the electricity bill remains to be seen, but around 10 units per day on avg should be added to usual home bill.
I was already considering a 6-8 kw solar system for home, and (if possible in future IA), replace my civic x with a 4th gen Prius PHV, so I was wondering if my solar system would be able to charge my cars, as well as run an AC or 2 in daytime. I have read about 3 amp limiter for newer Haier/Candy ACs for use with solar/UPS. And the other Prius will consume 16 Amps (around 3400 watts), but will be charged only occasionally (not necessarily together with the older Prius). Ideally, it would be nice to have older Prius (2200w) be charging together with at least 1 or better 2 inverter ACs running at 700-1000 watts (3-5 amps ea.), throughout the daytime under ideal conditions, for all other times, grid could be used.
I have limited understanding of technical aspects of solar, etc. so my question to respected experts here is what sort of solar system should I get. Objectives are 1) Charge car(s) ideally on solar in daytime, 2) Have net metering for overall reduction of annual electricity cost, 3) Run ACs during daytime on PV as a bonus, as well as reduction in wapda consumption, 4) Ability to charge during load shedding, 5) We have UPSes working fine for general use (no ACs) so load shedding is not really an issue so far. Or maybe I am on the wrong track and best would be to just get a net metering setup and use wapda normally for everything, and not charge or run ACs during load shedding (it will not continue forever hopefully). TIA and appreciate your patience for this long post. Hope it helps others.
