in fact it should be the duty of installer to tell the user how to use inverter.
I think mostly default values work we just need to add battery backup value and we dont need to change all other values..default/factory values are fine.
What problem you are facing? is your netmetering ON?
In case of an error it rings the alarm for a minute and restart the services by itself, check error codes? did you check?
you have the tool you just need to understand what working mode suits your need.. i suggest don't do experiments by changing unknown fields values they are not like our mobile devices.
