Dear friends,
I am sure I am at right place and I will find my answers which I am really looking for. I am using UPS since 4 5 years and you can guess I know a little bit about all these stuff so I hope you will not find me so dumb to pick your technical replies
I also tried to make my question clear below and I apologize if I could not though.
WHAT I HAVE?
- I have UPS (GHOTKI MADE) 1200 WATT named as MicroTech which I am not sure if its proper brand or just local made. But its heavy and not the china one you know.
- I have two Solar panels 150 watt each (German cell, written on it) bought last month JULY 2015 (7500, each)
- AGS batter 27 plates.
QUESTION 1
Why my UPS battery which I bought in Februry 2014 and its almost one and half year is too hot and its water is almost started boiling?
I mean its enough time period for a AGS battery that its done now?
It just started few days ago. So here I need to know how to check if my Solar panel, 1200watt UPS and 200F AGS battery configuration are correct? I found very dumb electricians here so please advise here how to make sure this.
Can be the problem due to over recharging? We have almost 8-9 hours light out of day in average and in day light I have two solar panels (total 300 watt). I am thinking that may be my configuration is not correct. May be its too over for batter?
I have attached the pictures to show how is my setup.
QUESTION 2
I have PWM controller for solar you can see in pics. It always or 90% shows the symbol which I found as LVD (low voltage disconnection). Does this mean my battery was not working fine since I installed solar? The PWM shows correct recharging signal once the electricity is ON and battery is being charged from both UPS and solar so after half an hour it starts to showing that solar is working now. So please tell is it correct installation to have 2 solar panels with 200F AGS battery?
In the end, please advise what to do with AGS battery? I kept its lid open all the time. Should I replace the battery? A
I use one celing fan, one DC fan and laptop and one light. I will appreciate much your help on this. I just want to understand that if my setup needs any correction.
Thank you very much.
Zeeshan Ali
