NITTO TERRA GRAPPLER ALL TRRAIN LT305/70R16
With LENSO Ventilated Performance Wheels.
Will Be Used As Second Set ...
Dual Sidewall Designs
Each Grappler has two sidewall designs so you can choose how your tires look. On the Terra Grappler one side has solid outlined lettering and the other has striped lettering. This feature was an engineering feat since even a small weight imbalance can cause unwanted vibrations. Nitto produces exceptionally uniform off-road tires even with different designs.
Multi-Purpose Traction and Handling
The tread pattern void ratio is balanced for off-road traction and on-road handling. Coupling joints between tread block elements reduce excessive flex for better traction and steering response on and off road.
High-Density Siping
Deep sipes and lateral voids effectively channel away water. Siping helps resist hydroplaning by cutting through pockets of water on road surfaces. This technology provides all-season traction.
Off-Road Performance
The lugs on the shoulder are staggered to improve traction in deep sand and loose dirt.
All-Season Performance
Angled, lateral voids were engineered to channel away water in wet conditions and provide forward stability in dry conditions.
[TABLE="class: compositeRatings, width: 279"]
[TR]
[TD="bgcolor: #000000, align: center"]Overall: 4.6[/TD]
[/TR]
[TR]
[TD][TABLE="width: 269"]
[TR]
[TD="align: left"]Dry[/TD]
[TD="align: center"] 5.0[/TD]
[/TR]
[TR]
[TD="align: left"]Wet[/TD]
[TD="align: center"] 4.0[/TD]
[/TR]
[TR]
[TD="align: left"]Snow[/TD]
[/TR]
[TR]
[TD="align: left"]Handling[/TD]
[/TR]
[TR]
[TD="align: left"]Comfort[/TD]
[/TR]
[TR]
[TD="align: left"]Noise[/TD]
[/TR]
[TR]
[TD="align: left"]Treadwear[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
