Make : Toyota Land Cruiser 80 Series (FZJ80)
Year : 1997
Body Color : Golden/Sliver
Body Shape : Squared 5 Door
Suspension : Soft/hard
Engine : 1FZ-FE (4500cc)
Fuel Type : Petrol
Transmission : Auto 4x4 (LSD)
Wheelbase : Long
Interior : Brown
Options : Sunroof, Power Windows, Power Lock etc
Token : 2016 Paid
Condition : All Stock So Far With No Accidents Or Touch-ups
Jeep Club : Frontier 4x4 Club
Purchased Date : 23rd March, 2016
Exterior :
Offroad Wide Fender Flares Set
(Installed)
Bug Shield Front & Back (Installed)
DEPO 6 Piece Set Front Head Lights Crystal (Installed)
Interior :
All Original
Engine & Gear :
NGK IRIDIUM (IX) Spark Plug - 6 Pieces (Installed)
Aeromotive 11140 Fuel Pump 340lph Stealth Pump (Pending Installation)
Magnecor 65234 8.5mm KV85 CN Series Ignition Cable (Installed)
Nitro 4.88 Ratio, Nitro Front & Rear Gear Kit (Pending Installation)
The "TRU FLOW" Toyota Timing Chain Kit (Pending Installation)
50mm 13 Row AN-10/AN10 Double - Deck Oil Cooler Hose Filter Relocation Kit (Pending Installation)
Exhaust & Headers :
American OffRoad "Dholki" & Ganador Muffler Single Tip (Installed)
Borla Cat Back Exhaust System Purchased.(Installed)
Genie Headers Long Tube Set (Installed)
MangaFlow 23622 Catalytic Converter Front (Installed)
Kool It Heat Warped On Headers(Installed)
Kool It Heat & Rust Proofing On Headers (Installed)
Heat, Rust & Sound Control System :
DYNAMAT 72 Sq ft Heat & Sound Proofing Inside (Pending Installation)
Rubber Coating Water & Rust Proofing Under Chassis (Pending Installation)
Suspension, Break System & Axles :
4" Lift Kit Stage-2 Suspension Package " PEDDERS " (Australian Brand For Suspension Solution)
1.5" Front & Rear Polyurethane Coil Springs Spacers (Installed)
The 4" DropBox Kit (Installed)
Nitro Chromoly Birfield & Axel Kits (Pending Installation)
30 Spl, Nitro Chrmoly Rear Axel Kit (Full Float, Pair) (Pending Installation)
Heavy Duty Axles & Bearings Kit by NITRO (Pending Installation)
Draglink Chrome Moly 4140 Steering Arm 38mm (Pending Installation)
Solid Chrome Moly 4140 Tierod Rock Rod 38mm (Installed)
Wheels & Breaking System:
Mickey Thompson Baja Claw Radial 35x12.50R15 (Installed)
Mickey Thompson Rims 15" Light Weight 10" Wide (Installed)
G2 1.5" Wheel Spacer Black Coated Aluminium (Installed)
The Hawak Performance LTS Brake Pads Front Set (Installed)
The Hawak Performance LTS Brake Pads Rear Set (Installed)
Bumpers & Winch :
Front Off-Road Bumper (Branded Ordered 22/082016)
Rear Off-Road Bumper (Custom Design Pending for Desgin)
Winch Warn Zeon 10 Premium Series (Pending Installation)
Performance Parts :
K&N Gold Oil Filters (Pending Installation)
K&N Pro Oil Filters (Installed)
K&N Air Filter (Installed)
ARB Safari Snorkel V-Specs SS81HF (Purchased)
HPS RED Reinforced Silicone Radiator + Pesky Heater Hose Kit (Pending Installation)
Lighting System:
Rigid Industries Radiance 50" Red Back Light LED Bar - 25002 (Pending Installation)
Rigid Industries Radiance 30" Red Back Light LED Bar - 23002 (Pending Installation)
Entertainment System : (Pending Installation)
Head Unit
DVD/GPS Unit .... (Searching)
Front Stage
Speakers .... (Searching)
Focal FP 2.150 LE Amplifier (2 Channel Dynamic Capacity 1 x 400W rms available into 4 Ohms)
Rear Stage
Focal Solid 4 (400w 4 channel amplifier, With 4 x 75W RMS power into 4 Ohms and 4 x 100W RMS into 2 Ohms)
Woofer :
Kicker S15L7 Solo Baric (2012 Model)
Kicker ZXS 1000.1 Amp (2012 model)
Monster 202LN High Performance RCA 5m Lead 2 Channel.
Kicker PKD1 3000watts 0 Gauge 6.1m +ve & 1m Ground / Kicker Fuse Box Kit
Kicker Woofer Safety Grill
07-07-2016
25th June 2016 - Installed Only Suspension + Wheels
