[h=2]11140 - 340 stealth fuel pump[/h]
good going brother. sweet ride.
G2 Spacers 1.5" (Black)
These wheel spacers are CNC-machined from heat-treated T-6061 aluminum and are anodized for corrosion resistance.
K&N Performance Gold Oil Filters HP-1002
Keep your engine free from contaminants as small as 10 microns with these Performance Gold K&N oil filters. They use a resin-impregnated filter media to provide maximum filtering and an inner core to lend extra structural support to the filter, preventing filter collapse. Plus, many of these K&N oil filters have an anti-drainback valve (where applicable) that eliminates dry starts and prevents oil from draining back into the crankcase during engine shutdown. And they're protected by a heavy-duty outer shell that guards against rock and stone damage and provides over 550 psi hydrostatic burst strength. So, if you want golden-level oil protection, then you want K&N oil filters.
[h=1]K&N Pro Series Oil Filters PS-1002 = 4 pieces[/h]
These K&N Pro Series oil filters embody the spirit of performance racing with their new, sleek canister design and filtration media. They feature a black fluted canister with stronger sidewalls for higher burst strength, and a newly engineered filter media that provides outstanding filtration and flow. This allows for a high volume of clean oil to keep your engine lubricated and protected from harmful contaminants. The filters also come with a pressure relief valve, nitrile rubber anti-drainback valves (where applicable), and rolled threads to help prevent stripping when installing them. K&N Pro Series oil filters are co-labeled with the K&N and NASCAR logos and are designed for removal with a traditional oil filter wrench.
K&N Washable Lifetime Performance Air Filters E-2443
K&N's washable lifetime performance air filters are designed to increase horsepower and acceleration, while providing excellent filtration. K&N makes over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom-designed to fit into your existing factory air box. Their drop-in design means that adding performance is simple. With most vehicles, you simply remove the disposable air filter and replace it with one of these K&N air filters.
Thank You
Finally Received The Genie Headers which was a Very Quick Delivery
Unpacking ...
Looks Good To Me ..
Heat & Rust Proofing Setup ...
Coat 1 ..
Coat 2 ...
Finally Ready In Morning ...
Warping With Heat Proof Tape & Then Heat Proof Coating Will be Done Today ...
Excellent
Congrts bro... Best of luck...
Thanks
Nice work here man... I will contact you once you have done everything :)... mainly for the procurement of the equipment I want to upgrade. I am close to Abu Dhabi as well.
For now all the best...
Cheers,
Bilal
this will eventually turn out to be sweet ride/unique one (like ur other projects)
Do you plan to sale it in future ya raknay ka plan, because I am in search of such a thing... agr apka sale krnay ka plan hay tou please leave a message or text me, if not then please ignore my message.
Muhammad Saad0311-7543461
Sherry bhai this is just phenomenal!
Good luck with it.... I wish you could bring it to UAE so we could all see this beast!
Continuing The Headers Heat Proffing ...
Warping ...
Coat 1
Final Coat ...
Ready
Replaced To Original Headers ...
This is will keep the heat level Low in Engine Bay ...
Some of More Heat Control Items ..
A Transparent Coating For Engine Bay ...
A Sliver Coating For All Under The Body
A Red Coating For Engine Head
A Black For Air Filter Assembly
For Engine Belts
The Hawk Performance LTS (Light Truck & SUV) brake pads (Front & Rear) Received .
Aftermarket " DEPO " Rear Lights Received.
