After A Long Homework I decided To Go With The New Technology For The Lower Arm Control & Clearance For Steering Arms.
For years The Toyota Landcruiser around the world have had to persevere with track rod clearances and castor correction issues when fitting 3-4" to 6" lift kits. Common options have been either castor plates, Castor Correction Bushes (1 Degree to 5 Degree Settings as per the lifted height).
Introducing the all new Castor Correction DropBoxes Kit to suit Toyota Landcruiser 80 Series & More ..
In Pakistan Most of The Mechanic Do Not Measure The Correct Angle Degree During The Installation Of Caster Bushes (I Had Experience In My Devils Pride Project & Finally Did My Self By First Learning Video Tutorial Online)
The New solution to get rid of the caster correction bushes and castor plates adjustment the so Called "DropBox Kit" is here which i ll be also using in my Devils Den Project. They are simple to fit, deliver a desirable degree castor angle at 4"/100mm lift, and allow further tuning of castor angle using offset bushes to trim the final angles using your original radius arms. Design is super strong, negates any lateral load issues, and assist in creating the correct angles and clearances at lifts from 4-6" lifts.
"The Major Advantage of Using Drop Boxes Kit Is That It Preserves The clearance of The Steering Arms Over The Leading Arms"
It Also Gives No Wheel Wobble Anymore & The Steering Is Much More Responsive. It Seems To Be TWO PIECE of Metal But The Results Are Way Too Good
This Is Very Famous Gadget In Australia & Most Of The Rigs Are Equipped With This System Now ..
Features:
Suitable for 4"+ Lifts
Engineered to precisely fit the vehicle
Easy DIY BOLT-IN (no welding required) Fitment
Supplied with comprehensive Fitting Instructions
Zinc Plated for Corrosion Resistance
Left Side With Dropbox Kit & Right Side Without ..
See The difference & No Castor Plates Or Bushes Installed Yet
Much Better Clearance & Alignment ...
costing nearly 66,000/- pkr + Tax 8350/- = 74350/- Pkr
To Get Lifted Vehicle Even By 1" High Is Easy For Every One, But Following The Correct Rules, Line & Length For The Articulation OF Vehicle & Related Sectors To It Is Not Easy To Understand ...
We Have To Learn A Lot In This Field & Em Trying Best Always To Learn More & More So That I Can Come Up With New Solutions / Technology & Share That knowledge For Better Future..
