chill - man, I knew it was a screwy deal. Why not have some old fashioned interrogation with it - u know like when you play poker and you know the other guy is bluffing
Sir this guy is using Chinese low quality Rs300 DMM, without scope plots its almost impossible to do such critical tuning stuff
Na Kar Yaar...MEin NE 450rs KA Liya Tha ANd It Serves ME Quiet Well......
B.t.w With Multi-Meter...HE Can Only MEasure Voltage Outputs Doesn't Mean It Tells Everything...
A WIDEBAND Sensor Is This Regards WOrks Much Better That This All.....
This Reminds Me Of One Old MOD Of IAT Sensor.....You Will Get It.......Install A Pot Resistor In It And Adjust It And Measure Fuel AFR's ....
It Will Tweak AFR's And Give You A Bit Room To Play WITh IT....! Its Tricks We Can Play But He Just Want To NAME It SOME INVENTION And Want Us To Believe ON WHat He Say....! Like We Are SOmeone Out Of This World
Man whenever u use this term "CNG HYBRID" it makes me laugh like hell i dont know y
yes - we can use such a meter for analog static readings or even readings that change about 3 or 4 seconds, not in milliseconds though - that is why we use a scope. You have a weird bunch of claims here. Either you or your customers are really naive who believe in emotion rather than logic.
so you calculate needle oscillation to ascertain the 'mV' feed ? how many oscillations of needle per mV per 3 seconds ? for optimum settings please state in digits - no rant please
remember plenty of us are not from PIND_E
it is a case of a dog's tail for sure
capsat - its a situation of a person saying he can map 40mb on a 2mhz range using a dialup modem connected to the feed of the earth parabola unit.
How does that work?
over copper lines with line attenuation of -4db chalay ga size does matter 40M bara hai ya 2Mhz bara hai - baknay mai koi haraj nahi hai itna jhoot boloo jo khud bhi bhol jao k sach keya hai - Khapay Khapay
read post 381 @ page 20 please-and answer my question at 411 too
Are there any update for trying EC1 on some Bakra.
Look for yourself, this bakra has EC1 installed, it now gives lots of milk and meat on a daily basis:
This is the EC1 CNG Hybrid model, gives excellent gas:
This EC1 Bakra model is a demo model:
