liana de vinci says hi and belated EM to sial BHAI:D
Aamir Bhai why you got the shims done. What were the symptoms before or you just got it done as preventive measure?
Emad bhai,car was not breathing well due to these two valves,they were not lifting properly and there is no harm in grinding the shims to the specs of all other shims,this is part of tuning,where you do not adjust the bolt like sohc.
throttle body was not that dirty to be washed with carb cleaner,so was just washed with petrol,reason i drive the car on petrol most of the time like in city traffic and it runs on cng for long routs.
Time to go under the car and open up sump drain nut for oil change.
your rxi in black is looking awesome
thanks for the compliments.
oil drained out after about 3200 kms.
due to non availability of Zic A at the spot,experiencing for first time SGO.
good going amir bhai:)
thanks for the compliments nauman bhai,what about your ride,is it all right now,after the ventures of your brother in law:)
SGO 10/40 api sm 4 liter for 2200/=
oil filter oem for 890/=
lol. it still need some work. timing was retarded while change of gasket during my trip to northern area. will be shortly getting its timing adjusted and shims checked.
Plugs changed after about 15k kms which were of platinum tip and this time bought from 3s for 960/= a set of four which are simple ngk bkr6e.
gear oil ready to be exchanged, 2 liters is recommended quantity for this vehicle.
please re-check from the owner's/ service manual. i think it is 2 ltrs
i have got it poured above recommended level, mistakenly.
zic 75/85 410 per liter.
during service seen the steering rack boot a bit damaged so changed one oem got it for 1150/=
