well today i decide to clean & reduce the gap of spark plug as it wasn't starting on cold. I tried starting it but today it just refused to start. So I decided to check the plug wire for loose connection. starting from from driving side i checked each plug wire one by one by removing it.
1st one was ok. 2nd was a bit loose, i pushed it hard, still it was loose to spark plug. :S
then when pulled the 3rd plug wire about 4 table spoon oil came out and it was all wet. :o
then when I pulled out the last one again oil came out with it. (A):o
So I decided to clean it up and install it back. Then gave 3 selfs & again oil came out when I rechecked it.
So what could be the cause of oil.???????? the car is in garage and not starting. so I left it there.
