Dear Baleno Master & Car Experts,
I have a Baleno 2003 JXL (Spoiler Model) on petrol only in exceptional condition but for the past few months I am facing strange kind of problems which I had never experienced in the last 13 years with this car as I bought it brandnew. Today the car has done 181000 Kms genuine miles and still the engine is in perfect condition as I use Liqui Moly 10W-40 (Made in Germany) engine oil of 3200rs from Hamd Autos Muqqa Chowk Karachi. The car since bought has never been overheated in the last 13 years as I have used coolants of Mercedes Benz, ZIC, Liqui Moly, Whiz, Caltex, etc.
What I have done to date when coil problem came in my car 1.5 years back:
- I have installed both Genuine Coils for 19K rs, bought them from Suzuki Altaf Enterprises in Plaza, Karachi.
- Throttle Body got cleaned with Nasa Carburettor cleaner whole big can used to clean.
- Fuel Injectors are cleaned with Fuel Injector cleaner of Whiz USA brand.
- Liqui Moly Fuel Injection cleaner (Made in Germany) 4 bottles were used while driving to clean the system.
Now the present problem & the most strangest problem that couldn't be diagnosed by any Suzuki Authorized workshop and even my Highly Skilled Mechanic:
- When I start the car the car does buph buph, vibrates and rpm dances up & down and goes to 2000RPM for 2 to 3 times and stays there for 3 to 4 seconds than drops down. (Strange and Weirdest Problem)
- While driving Car's pickup finishes in 1st & 2nd gear, both with and without A/C (Main Biggest problem)
[U]What Mechanics, technical experts advised and what I have done in the past few weeks:
[/U]Got the car checked professionally by technical experts, few say injectors should be cleaned, few say fuel pump should be changed, few say A/C compressor or condensor should be changed, few say sensors should be changed, Card should be doing the problem, some say there is a wiring fault, etc etc.
Only one technical expert seemed best to me, he told me that he will take the negative wire of the battery out so that all errors are finished and injectors will be cleaned through giving them current. This helped out but just for one day and the car was back to where it was. My Baleno is having severe pickup problems during driving and it takes alot of load on A/C. I use Brandnew Genuine parts and I know about parts alot, Baleno's parts are extremely costly and I mostly purchase from Plaza and sometimes from showrooms. everything is available but it costs alot. Like Injector costs 20K per piece, no one can afford that. One Expert said you need to get kabuli injectors if the problem was solved by cleaning them and it appeared again. He said this is 100% fault of injectors but no one is sure if I spend 3000rs or more on Kabuli ones will this get solved or not?
Xulfiqar Bhai I need your sincere advice in this regard? Have I been doing anything wrong or have I missed something?
