Your car is one of the most important and most expensive gadget that you own. It is important because you will really lead a peace of mind if your car runs trouble free. Always follow the manufacturer’s recommendations and prefer to go for the original spares.
That's not to say that every repair will be inexpensive—timing belts, for example, are notoriously expensive to repair regardless of the make or model—but here are a few ways to make sure that few thousand Rupees job doesn't turn into many thousand Rupees heavy loss at the end.
The most fundamental and essential element of not getting ripped off by your mechanic is to only do business with an honest shop. The honest shop means a shop with experienced knowledgeable professionals having the full resources and performing quality job.
Timing belts don’t often give you a lot of warning when they’re about to give way – they might squeak or chirp, or they might just suddenly break. More often, though, damage is due to wear in the timing belt. It may happen even you have recently replaced the timing belt and it is kept over tighten by your mechanic by having a little knowledge about its consequences or the belt has completed its period. You can do a visual check – see if there’s any cracking, glazing, missing teeth or oil contamination. Or you can have a mechanic check the belt for you. Most vehicle manufacturers also recommend that you make timing belt replacement a part of your routine maintenance, replacing it every 100,000 km. If you’re in doubt, check your owner’s manual, or ask your dealer or mechanic. Often we make a mistake by choosing a costlier original OEM part and ruin it by giving it in some un experienced hands merely cutting down few hundred labor charges
if the timing belt breaks, you might end up with bent valves, and you might have to have your cylinder heads rebuilt, which result to end up with a heavy monetary loss.
Now you know the disastrous consequences of neglecting your timing belt – engine valve and piston damage, bent valves, cylinder heads that need to be rebuilt or replaced, and possibly even total engine destruction. If you don’t want to see those thousands of Rupees signs adding up, check your timing belt regularly, and have your service Personnel replace it on schedule.
