Aoa to all. Its rainy season and you all know when we drive through water, the moisture gets into the distributor casing which causes the engine to stop. I've found that it happens only when the left front wheel moves through water as the left wheels water shower clearly hits distributor. Should I install some protective cover at the bottom. Secondly, isn't installing it will cause heating problem as it will stop air flow from bottom. You all know the front grills of baleno are not big enough (like a rolls royce
) to allow sufficient air flow.
Advance appreciation
