I also have a issue with my Baleno. The issue occurs when the car is in 1st or 2nd gear (in higher gears the jerk is very less). While the RPMs are at or above 2000, if I let off the accelerator, the RPMs drop as they normally should. However, once the RPMs fall below 1500, the car starts to jerk.
I got this diagnosed, and according to the mechanics, there was play in the gearbox where the CV axles mount. As a result, the entire gearbox was repaired. Unfortunately, the issue still persists.
Later, another mechanic suggested that the problem might be electricalâpossibly something related to the current or wiring. He recommended changing the coil wires, which I did. After that, the car ran okay (not 100%) for a while, but now the issue has returned.
Can anyone help me in this issue?
