bhai get throttle body,injectors cleaned etc cleaned.don't understand....it doesn't downshift after accelerating hard?
in auto transmission when you suddenly floor the paddel it shud jump to high rpm and as a result speed up. but in my scenario when i floor the paddle it slowly gains the speed and rpm goes up slowly.
It can be due to number of things like faulty TPS, TPS calibration, shift solenoid, Wiring, Speed Sensor, Ecu etc. Get it diagnosed by good workshop/mechanic otherwise it will be lot of trial and error.
Yep that's due to torque converter....that rpm suddenly goes up but speed increases gradually.
I think in his case rpm also goes up slowly
Han gii.
she's being standing from many day's not getting time to do work on her. it's an old pic taken when alternator died and she's not starting up
i think i didn't share the problem i faced with the temperature gauge. When i wired up the car i missed the wire of temperature gauge which is connected with the sensor on engine. So i install new wire but still it doesn't work i thought that gauge gone bad. My father told me that it's 6volt gauge but i thought 6 volt gauges might comes in old models probably it would be 12 volt. So i checked with the voltmeter it's 6 volt but voltage is pulsating or missing so i checked the gauge with 12v it fine but going up with much rapidly which show that it's 6 volt.But now problem comes that where the hell 6 volts are coming from and why missing....so me and my father check the meter thoroughly. Now 6 volts are coming from fuel gauge and it gets 12 volts direct when ignition is switched on. there's 2 coils on fuel gauge one is connected with the fuel needle and other coil is connected with the temperature gauge which is decreasing the voltage and then forward it to the temperature gauge. We clean that coil terminals and grease them, now gauge works fine.Ya sab cheez na use krna ki vaja sa huva.
I got problem of engine mount..front driver side..it was broken (not from the bush) when he was removing the mount mechanic hit the steering oil pipe which leaked ..and I have to fix it..Mechanic told me to weld the mount and it will work...because bush was OK..Then I changed my car battery ...as previous owner had installed it in 2013 phenox battery....same new Phoenix 2017 is installed by me..I am nothing long and sometimes short self...After u have narrated ur starter bush issue..Car starts on er er er er er er ....7 er
I have started to miss my AE90 which i sold some days ago.
Such a long story ek dam hi bhai meri gari ki baat kr raha? starter ki?
what you bought now?
I have bought nothing yet.But starter py shak ho raha ha..sometimes short self...and sometimes long self while starting..
Did you feel any speed difference while car is cold or hot? What is the average speed of starter?
Nothing yet brother. Driving my brothers gli 2013 these days. Was getting a good deal on ae100, 1999 model 1.6 gli 4afe manual black colour but the car was sold when i made up my mind
Starter revolution speed is constant all the time.
Yar Have been listening to the tappet noise since I rebuild my car engine..Car ki pick fine ha..Just cold start MA sound clear hoti ha tappet noise ki..Mechanic na kaha tha k issy teek krny k liye head etc nikalna pary ga and have to take it to the engine rebuild mechanic...
Right......and for how much it got sold?
4.80
then bhai starter is fine.bhai these engine's have hydraulic tappets.....which are not adjustable only replaceable.
