If your from Lahore take you car to bilal gunj and they will lower you car according to you demand. Or you can bought them if you want to do it yourself. It would be cheap rather then buying from a shop that only deals in such items.
You mean they will cut my factory fitted springs and lower it that way.
No! Not until you ask for that.They will install soft springs or hard springs according to your demand.
Ok thanks...but Im in Peshawar, do you think cutting springs is ok?
It will work....but original springs allow greater to and fro movement then lowering springs. Dropped cars should have less movement then stock (depending upon how much it's dropped ). Lowering springs not only drop the ride but also decrease the movement while cut stock springs doesn't decrease the movement and wheels are always inside the fender.I also have cut the springs in front of my ae80 but in rear i installed lowering springs.
u can install XE corolla springs and keep original set with you.
Are the springs the same, can I do that?
Thanks, great help!
Cutting springs will make them stiffer
yes they are same. i had in my 82 and have to add spacer due to low ground clearance. here in rwp few speed breakers are too high and that grrrrrrr sound on speed breakers directly goes to heart
No. Stock springs have less rounds then lowering springs, cutting them decreases stiffness. I'm saying on experimental proof.
Your welcome.
It's not only grrrr, it's like " thak and a pause then grrrrrrrrrr"
Anybody know anyone in Peshawar who can repair a Ke70 dashboard?
Any good place to get 82 parts in Rawalpindi, had one of my fender mirror broken....
Shamsher AutosZarGul Autos Both are near to Glass factory choke and famous for old corolla parts in chah sultan.
Thanks, planing to go this weekend. Where is this shah sultan, directions will help, coming from Mardan on motorway
do check availability in shoba bazar its near to you
Not available there, they mostly deal with newer cars now. Hard to find stuff for older cars like 82 and 86.
