Oh sure thing bro, i'd be happy to see you. I might also drop by UAE for a couple of days by the end of january inshaAllah, working for a humanitarian cause with Dubai Cares, too.
Kher, yeah you're right, thing keep coming so the filthy expense of time & money. I'm currently caught up with some work hence not proceeding but shall start with both the front and rear lip spoilers sometime by this weekend. Already had planned surf's d.b.booster, your experience further strengthens the faith. I'd also replace the break (oil) lines with those of either surf ones or old-school merc ones that had aluminum pipes inside the rubber layer.
I had the rear camber made adjustable too, it helps quite towards managing the traction as I have disabled the ETCS for some particular reasons. For same reason, I have dropped the vehicle down to lowest possible so to be able to add to traction, and clearance manually & physically. Also, would try to add a strut bar to hold tight the rear shocks too, but currently 'm not sure of it's possibility due to the centrally mounted in-boot fuel tank.
Wish me Godspeed:D nice talking to you mate, take care
