Thanks a lot brother!
Regarding your car, what is the current odo reading?
Low coolant reading is not good, get it changed ASAP.
If your car has clocked above 40,000 km, get ATF an brake fluid changed as well.
Check the condition of the AC and Air filter, better replace them with OEM ones.
Check the spark plugs, if necessary, change them as well.
Check the tires, if they're not in good health change them too.
Get the brakes checked and replace them with OEM parts if required.
Check the wiper blades and get them replace if needed.
My car is due for the ATF and brake fluid change, will be doing that any day now.
