Take ur car to time motors.
Can any buddy tell me, my prius 2007 starts engine to soonLike mostly it runs on fuel which results the average to 15km/lCan any buddy explain the issue and solution please
Any check lights pr ECU fault codes ?
Bro no fault code,no dtc at all
Did you service the throttle body? If you have, kindly remove the battery terminals, wait 30 secs, reconnect, issue resolved
I am also facing same issue.As soon as i put my foot on accelerator,engine kicks in.And I have seen many priuses having no or very less sound when running on roads but my prius makes a "Keyein" type of noise as soon as the engone kicks in.Mileage is also bad.Only 10km/l.No error code.Got it's throttle body serviced from Toyota Eastern.Please help me what should I do?
Does the battery drains quickly?The engine does kick in when u press the accelerator hard so u have to be light on throttle Try resseting the averageHave u changed air filter,oil and oil filter?Are plugs in fine condition?
And .. Here's mine....
Tooo bad i am selling her now.
No i mean engine kicks in as soon as i put my feet on accelerator.Secondly yes i got original air filter,oil filter,cabin air filter and Toyota 5W30 oil.Resetting means through MFD ?Yes i tried it no help.I don't know the plugs condition will get them checked.Can it be due to that?
Does the battery drains quickly? Whats the odo reading
No battery does not drains quicklyOdo is 103000 kms
When my father used to drive it with normal foot,it used to give us around 15.3km/l.Now my driver drives it and average has dropped to 10km/l Heard people are getting 20km/l from these cars but could not achieve this since i bought this car.Please also help me regarding the "Keyein" type noise i have mentioned above.
Dont khow about the 'keyein' soundHowever let experts answer you i am getting 18.8 with normal driving and with eco mode and light foot it goes to 21 or 22 easily(All depends on driving style and techniques )
@mharoonzaheer have u checked the car's injectors? Also i want u to do something. Can u drive ur car at around 75~80 km/h, put it on cruise and check what readings u getting regarding ur average. I want to check what condition ur engine is.
@addictivesundew By cruise you mean that i accelerate it then let it go without accelerator?If this is what you mean,I even get 99km/l(instantaneous) with this. I will get Injectors and Spark Plugs checked.What might be the issue of the noise?
Can you refer any place in Karachi that can be of help in this matter?
I mean drive around with cruise on @ approx. 70~80 kmph for around 1~2 km and tell me what average u getting at that speed alone.
I think 1.5 does not have cruise?
Bro injectors have nothing to do with quick engine start ,n G Touring 1.5 have cruise unit
