You need to change inverter. You can find it from scrap market.
Sent from my SM-N920C using Tapatalk
What is it's cost?Couldn't it be because of Inverter Coolant Pump?
Because first there is just a triangle and check engine light then after sometime of driving this appears.
Couldn't it be because of inverter coolant pump??
Also tell me price of inverter or inverter coolant pump
PUMP COSTS AROUND 8K and INSTALLATION LABOUR 1.5K
COOLANT I THINK UNDER 3.5K WITH LABOUR
THATS IN LAHORESHOULD BE CHEAPER IN KARACHI
WASSALAAM
And the pump you are talking about is new or used and is it available readily.
Mostly new
Usually we have them sourced readily sometimes there are shortages
Kindly contact on whatsapp
Wassalaam
I need TOYOTA PRIUS (2011 zvw30) front Fender Liner, (AKA mud guard/splash guard/splash shield that goes around your front wheel ). Anyone have info, from where I can get it
Sent from my SM-G935F using PW Forums mobile app
try some scrap yard aka bilal gunj etc
http://priuschat.com/threads/engine-always-running.120990/
This might help for continuous engine running
Good sharing
A/C & HEATER SHOULD BE OFF WHEN CHECKING SUCH AN ISSUE
wassalaam
My prius 2007 is not doing more then 15 km/l .The battery is fine , have tried changing the plugs and have done tuning . No idea what the problem is. Even the scanner is not showing any problem. Can some one please guide me with this issue.
The problem is heat and driving technique
Today is cooler in most areas
Try driving without A/C and lighter foot
And then post the results
in rwp u can get new from mehran autos saddar for 5500 rupes ... thanks
can any1 share the cost of complete servicing of their Prius A/C with Gas refill
There is some kind of transparent plastic wrap on A pillar of Prius is it normal orsomething else?
Very common
Its normal
