@vitzrulz
I wont mind complete Kit either But the shopkeeper I went to said their are no H4 HIDS in purple available.So if you can confirm it. Kit is same for every colour. Its just the bulbs that change.
@hsumbal1
Welcome to Vitz Owners Club. Well About the RPM Meter I dont see any time which would refrain it from working. GO to any good decoration shop and thye will install it for u
@Rawfay
this horn looks too great when you are in mood of chill. Works Great in Special Events
@VitzRulz
Oh Yes - Will DO it. Will change after driving 1500 km more
@Yasirs_Vitz
Lemme try to anwser as much as I can
it has no push button start facility ... is it same in all vitz ?
Push Button start is optional and doesnot comes in all
the lower back is too low and when more than 3 ppl are in the car the car touches the ground.
I have driven with four ppls [Average weight 70kg each] at back with cng but didnot even touched on breaker. May be your car got 13" rims
the pick is very low in both cng and petrol
WIth me it got a nice pickup both cng and petrol. Infact not much difference in pickup in both.You need to go through tuning
the radiator sign is on while the car is running.
Its called Engine check light i Guess - It is on if you are running your car on CNG. ATleast this is what every one told me
it does not get start in first try.
Have you checked battery terminals ? they mite be loose.
Or may be you need to replace the battery.
how to use the etc music system.. i mean the dvd and tv in the car.
Varies from Model to model. Try Hit an trial
is the ac speed lower than corrola 2000 ac.
Not in my case. Its blow goes till back. May be you need a clean up
@All
Went to Nazir Automobiles today. He said car is perfect , no issue. Just I need to change the ABS Sensor. Can any 1 take a picture of the meter with every light on so i can know how many things are on meter . I dont see any temperature indication.
