salamz to all
welcome to new posters. u must join this forum if u r a vitz owner.
@ amoizp
Well, NLC number wont work. someone will have to take the car there and get it booked. if u have someone in KHI, ask him to do u this favor or go urself and get the job done. i will check if i have some khi NLC number.
As far as dust is concerned, it was obviously dirty from the outside as it is brought in open containers. but thats what happens to all brand new cars shipped from KHI. as far interior is concerned..no damn dirt can enter inside yaar. however, u can put a cover on ur car as a further precaution.
@ tyrone_40
thanx for asking bro. im looking for it in the mkt. 2 qoutations so far: 1 asked for 3500RS, other for 7K with fitting. Also contacted ALta, he gave me good suggestion of getting it done from some glassmaker using imported glass. his estimate was also around 7K. thanx to Alta. lets c wat else i find...
@ sd
i wont recommend deviation from OEM i.e
150/80R 13" (Tyre pressure 31 psi)
175/65R 14" (Tyre pressure 31 psi)
185/55R 15" (Tyre pressure 30 psi)
@ storm
difficult to agree with u on quality of plugs. watever plug u use, use double tip, thats what recommended by toyota. and bet me, they wont die b4 some tens of Ks. btw, why u wrote this "all these fancy plugs (like iridiums) make no difference to the 1sz-fe vitz engine". i would suggest denso double tip.
@ max414
well, mine AC is EXCELLENT,ALHAMDULLILAH. u can check AC with some mechanic for:
1: if vents and fins are cleaned.
2: if gas has good pressure and is not too old
3: compressor is fine
4: dont use fresh air cooling too much.
5: higher the speed of the car, more would be the cooling
As far as FM radio is concerned, i know no issue with freq advancer.
@ amoizp
Doesnt the Adapter require cassete player??? it sounds a good thing. i v heard its readily available on hall road Lahore.
@ waqas1972
hmm. nice VCD info man
@ usmantaokeer
oops, sad story. im telling u man, khuda na karay, if ur
Vitz starting giving problems, u wont b able to stop it.
@ all
all those turning to CNGs keep in mind that CNG definitely, definitely ruins ur engine. so b ready to spend all the CNG saving for some later time.
aur issi k saath khabrain khatam hueen. camera man mohammad boota k saath maani malung, geo lahore
