mere peyare vitz wale bhyaio
aoa
was away from pw in last few weeks due to my travelling. so here wish to share my experience with my bilori
last month i replaced her cvt oil and cleaned plugs as mechanic thought plugs are in good condition and no need for replacement
mechanic replaced cvt oil with fresh toyota cvt oil whole 4 liter box while some brothers said cvt oil qty should be 3.7 to 3.8 liter
further after cleaning plugs car started hell vibration specially when i stopped car in "d " , i thought may be its due to over filled cvt oil or may be plugs cleaning not appropriate so i pmed to ali bhai @murtaza_murti and as usual i received her prompt, informative responce
i followed his advise disconnect the battery terminal for 10 minuts and again conected , alhamdollila all issues solved , now mashallah my bilori dont having any vibration , even not a slight vibration which she having before cvt oil change and plugs cleaning, car running very smooth and feel bit increase in acceleration so kabh kabhi ecu re-setting ker lene chahye
ali bhai jazakallah for ur help and always being here on pw to help other members
vitz club kay members and overall aawam ki fallah -o- babood kay lye i am copy / pasting our pm here
quote
Re: vitz cvt
[INDENT][I]
[IMG]https://www.pakwheels.com/forums/images/misc/quote_icon.png[/IMG] Originally Posted by ahmad_yar
dear ali bhai
aoa
hope u are doing good.
i allways remember u when i need any technical advise so u can say i am selfish
ali bhai few days back i changed my vitz cvt oil
mechanic open whole chamber , also remove cvt oil filter and washed it with petrol and than reinstall, washed chamber inner side alongwith megnets with petrol and than fill the new cvt oil, he poured whole 4 liter tin and nothing was over flow , some of brothers on thread saying i overfilled the oil while it should be 3.8l while my mechanic saying since he also removed cvt filter and washed clean so require whole 4 liter and if he didnt remove/ cleaned filter than yes required qty isn 3.8l
my question is my mechanic saying right ? 4 liter cvt oil in chamber wouldnt harm for my car ?
another question
my car was working very fine before but after cvt oilo i also asked them to clean plugs , they did but after cleaning plug car seems in bit low rpm specially vibrate while stopping in d but after few moments its normal, before its also happen in d stop car very slightly vibrate ( very slightly ) but not like now which is more vibration
whats wrong ? may i need readjust plugs tip distance ?
ur responce will be appreciated
salam
ahmad yar
[/I]
Walikum Salam
Haha, no issues. It happens
Well, a full flush and replace consumes 4.1 liters of CVT fluid. So, don't worry you haven't over-filled anything.
I hope you got a new chamber and o-ring gasket.
Did your mechanic gap the plugs properly before installing them? Check the gaps. Also, remove the positive terminal of the battery for a minute and fix it back on. This removing of the terminal cause the ECU to reset to factory settings.
Let me know what happens.
Regards,
ali
unqoute [/INDENT]
