Day 2 (Today)
Some work remaining was done today
- Gear Oil (CVT) changed and gear oil pan and filter cleaned ( Labor Rs.800)
The gear oil which was drained was very dirty don't know how long it had been there
Gear oil was changed used Toyota CVT TC geniune Oil (4 Litre)
Oil pan was removed and cleaned along with the filter
CVT TC Oil 4 Litre with rubber seal (Gear Oil Rs.5400/- Seal Rs. 1560 both genuine)
After removing oil pan
After cleaning Oil pan
After cleaning gear oil filter
The nut used for pouring in the oil - TC written on it
Here goes the oil
The difference noticeable after oil change was gear knob shift has become smother now as it was slightly hard before
2. All brake service (Labor Rs.1000)
All the brakes were serviced
the front disk pads were in good condition but the disk plate surface was not smooth so it was given to kharadia for tool
After the tool from kharadia ( Labor Kharadia Rs.800)
Rear disk drum was Ok but the rear brake shoe were in bad condition so replaced them with genuine toyata brake shoes (Brake shoe genuine Rs.2900)
Difference between the new and old
After servicing the brakes the braking was excellent alhumdullillah no noise as before slight noise while in very slow braking was there and the hand brake is also much better now.
- Both rear shocks were changed with new genuine toyota shocks (Cost Rs.7000)
4. Wheel balancing and alignment (Total Rs.600)
All the wheels were balanced and alignment was done
