Salam everyone, I own a 2013 Vitz with 55K on ODO. I have recently started facing an issue, the car drives absolutely fine and smooth but at times on AC it becomes too sluggish like if i start from stop like a Traffic signal or taking a U-turn the car refuses to accelerate and hardly moves even I push the pedal all way down. It seems as if car is not picking race at that moment but as soon as AC is turned off it accelerates quite normally. This problem occurs mostly when starting from stop or trying to accelerate after braking if you are driving at constant speed there is no issue.
This does happen but not at all the times it does work fine with AC but if you are driving on around 50-60 kmph with AC turned on and then you turn off the AC you can feel noticeable difference seems like quite gain in power with AC turned off.
Need help to identify the issue guys,
thanks and regards
