Hi All ,
Need small information , i just imported vitz 2014 from japan but im facing 2 issues
1st issue , im getting very low millage , nearly 10.5 km/l2nd issue im getting Tuck Tuck sound on slope reverse Breaking.
Can anyone help in this regard ?
Dear Friend,
what is the current milage of your car. actually the answer of all those problems start from there
VITZ 2014-IMPORT 2017 AVAILABLE FOR BOOKING @ 1590000
Brother congrats First of all get you car properly tuned from toyota 3s. Gets its plugs cleaned, throttle cleaned, filters replaced. And also a computer check up. And also try to drive with light foot in eco mode.
Can you also further elaborate the tuk tuk sound as when it actually comes?
please confirm me the following for Vitz2014 model:
engine oil capacity
gear oil capacity
Aoa Haroon ,
Current milleage is 52,000 .
Thanks u nabeel for The wish ,
Can you please confirm from where in Islamabad I can visit to check it out my car ?
Basically my car porch is in bit slope so when ever I try to reverse it with using soft foot on the break it create some tuk tuk sound may it's from suspension may be or due to fault in any break . Meanwhile when ever I applied break on road I never experienced any sound
A.A as per milage there are couple of things you can do1 get the throttle body cleaned 2 change the plugs usually they come with irridium plugs they are good till 60 to 70k max3 put in a liqui moly fuel injectir cleaner in fill the fual tank and take it for a motorway spin atleast 100km4 get your transmission fluid check Once you do all that you are good for another 50k
You can take it to toyota capital motors. Only go to 3s. Don't go for outside mechanics.
And I guess that's normal. It must be happening when the car is cold. Try it after a 5 min drive. It's more like a grrrrr sound then a tuk tuk.
If the sound comes while hard braking than it is ABS engaging sound.
1- Change CVT oil (necessary)'2- Get throttle body cleaned.3- Use 5w30 engine oil (any good company).4- Get Cat Converter cleaned (Cleaned means cleaned not removed. Most of the mechanics will advice you to remove itthe)
Slam to all.Plz any budy tell i hav seen engine check lights on very soon after i poured high octane oil.What shud i hav to do, although i feel no problem but engine light on geeting on my nerves....
Get it scanned via OBD-II tool to check the exact problem.
Got 17" Enkei rims installed on my Vitz.
Another photo
i have vitz new spider shape..itz working fine..today sunddenly i the meter have shown the yellow engine light indicator..can anyone plz guide me what should i do for thz problm??
i have vitz new spider shape..itz working fine..today sunddenly i the meter have shown the yellow engine light indicator..can you plz guide me what should i do for thz problm??
i have vitz new spider shape..itz working fine..today sunddenly i the meter have shown the yellow engine light indicator..can you plz guide me what should i do for thz problm?? and where to go for solution?
Get it scanned with OBD-II tool.
from where?your suggestion will be higly obliged
