After discussions here with Xulfiqar & others, i did something insane today to my civic.
I wanted to recreate the scenario of a CNG mech fiddling with Throttle Stop Screw to increase rpm & de-calibrating the TPS by moving it.
Here it goes:
May car specs b4 fiddling
- Idle fine. 850 on Petrol & CNG both
- Turning on AC increases rpm by 100 on both Petrol & CNG
- Little jerk felt on every gear change
The Insane Experiment
- I screwed in the TS screw to increase rpm as mech do by giving it few turns
- Loosened the TPS bolts & moved it to & fro, so i dont know how much it moved
- did the same to Idle adjust screw
(i made a big mess of my ride
lets see if i can recover it)
The Voltage Readings from TPS
- WOT = 4.63v
- CT = 0.59v
The Come Back
- Unscrewed the TS screw but it could not move readings below 0.54v (previous 0.59v) as Throttle closed fully at 0.54v
- Locked the TS screw at 0.55v
- Checked WOT, It was 4.63v. so moved TPS & brought it down to 4.5v exact & locked the TPS.
- Checked CT, it was 0.43v. so tightened the TS screw again till it got to 0.48v exact & locked it
- Now everything is in order (or i thought so :)) CT=0.48v, WOT 4.5v
- Did an ECU reset & started the engine
- It started wobbling (later found a loose injector holder)
- with injector problem fixed, started the car again, the idle started surging from 1100-1800 repeatedly
- After abt a minute the idle settled at abt 1200 & stayed there refusing to come down
- Did i miss something? YES the Idle Adjust Screw
- Adjusted the idle with Idle Adjust Screw to 900
- Reset the ECU again
- It started at 1600 & i let it idle for 5 mins
- Eventually it came down to 850 & stayed there WOW
- Checked with AC on, increased to 950 WOW
The Results
- RPM back to stable 850 on both Petrol & CNG
- No problems with AC on
- WOT 4.5v & cT 0.48v
- Jerk on gear change vanished
So it is proved that u can safely rescue ur TB & TPS without buying a new TB if ur Ustaad screwed it up
THUMBS UP
