thats why it was asked, there were a few users here who went ahead and added dexron ATF to their CVT and burnt their gearboxes, verify the ATF requirement, it should be either stamped on the dipstick, or get it from the manufacturer, it will also be printed in the owner manual.
The ATF you show is a multivehicle HFM ATF (highly friction modified automatic transmission fluid) for shifting type transmissions - it will have a long list of proprietary atfs mentioned on it. The ATF is usable in transmissions that the list has, if your transmission fluid requirement is on the list then it is usable, otherwise its not.
