Following are the properties of LM Top Tec 1200G.
Hope you can find T-IV very clearly within the description.
Top Tec ATF 1200 yellow
DESCRIPTION Top Tec ATF 1200 yellow is an automatic gear oil from the latest generation based
on synthetic HC base oils in combination with the latest high-performance
additives. The outstanding composition of various base oil and additive
components ensures optimum stability to aging, excellent protection against wear
and good friction characteristics. Top Tec ATF 1200 yellow conforms to the
requirements of numerous unit and vehicle manufacturers and guarantees perfect
operation of the units even under extreme operating conditions and when exposed
to large temperature fluctuations. Also suitable for extended oil change intervals.
PROPERTIES - Outstanding viscosity/temperature characteristics
- Very high thermal stability
- Excellent low-temperature properties
- Optimal stability to aging and high chemical resistance
- Outstanding protection against wear and good friction characteristics
- Outstanding corrosion protection
- Multi-purpose
Specifications and approvals:
GM Dexron IIIH
Mercon V
JASO 1-A
Toyota Type T-II / T-IV
Allison C4, TES 295
Nissan Matic Fluid, D, J, K
Kia SP II / SP III
Mitsubishi SP II / SP III
Hyundai SP II / SP III
Mazda ATF M III / ATF M V
Honda ATF Z1 (without CVT?s)
LIQUI MOLY also recommends this product for vehicles for which the
following specifications are required:
Dexron VI
JWS 3309 (Aisin Warner)
Chrysler ATF +3, +4
MB 236.1, 236.2, 236.5, 236.6, 236.7, 236.9, 236.10, 236.11
Daimler NAG-1
BMW LT 71141, LA 2634, 7045 E, 8072-B
MAN 339 Typ Z1, Z2
MAN 339 Typ V1, V2
ZF TE-ML 02F, 03D, 04D, 05L, 09, 11A, 11B, 14A, 14B, 16L, 17C
Voith H 55 6336.xx
VW G 052 162
VW G 055 025
Volvo 97340 / 97341
Subaru ATF
