Now the update is I got an opinion of my 2nd mechanic as the first one has gone to his village. The 2nd one says it is a bearing problem which are yelling as belt looks fine. I am little hesitant
Sent from my Samsung mobile
How's the cooling of AC? You hear whistle only at turning the AC on or after turning AC on the noise comes continuously?
Sent from my D2502 using PW Forums mobile app
Coolant is not a core issue for me right now. The issue is to shut this yelling whistle first.
Sorry bro. Took it wrong i thought ur asking abt coolant.
AC cooling is perfect.
I asked about the cooling of AC?? Not the coolant... Does your car's AC work fine.
Yes I replied up...
If AC is cooling perfect then this might b a issue with the compressor bearing if belts are fine....If the AC cooling is soso then that might be a problem with compressor it self.
I don't know if the belts are OK. He says it's a bearing issue. first time I am experiencing this.
Belt wouldn't cost much.. Start from belts.. If your mechanic is confirm that its bearing noise then you can change the bearing..
Yes the cost of both belt is hardly 500 around 250 each. He will try to make the belt little tight then use a grease in 'garari'. I don't know what he was supposed to say..but.....I said OK and then back to work...
Don't know what has happened to my PW mobile app...... Its too slow..
Yeah the mechanics have their own language........ Don't know where the garari is..
Yup ...I will tell him to show me the garari.
The whistle starts when I turn on the AC and it continuous till I turn it off.
Went to my 1st mechanic to sort the whistle noise as mentioned up. So he checked and tightened the culprit pully by his 'pana'. Now he said to check if it starts whistling then need to change belt.
So.. Your problem is solved or still there?
Alhamdolillah ... haven't heard that whistle afterthat.
Finally bought two belts Bando. I will keep in spare for future.
Sent from my GT-I9500 using PW Forums mobile app
good to see 1st problem solved, for coolant buy only good quality and real.
