Price of Chinese tyres
175/70 R13Chinese tyre: 3,700 to 4000 per TyreInstall Continental which is 6,000 per Tyre
whatever you buy, ask shopkeeper to show you fresh dated bill of entry as proof of import.
if you are paying full amount of imported tyre, you should investigate if u r getting imported tyre.
for further info you may all 0300 763 6863
Shopkeeper usually show price list to show that they r giving us special discounts with no profit
Yokohama because its Soft
dear sir
pls also consider the effect of cat eyes on tires. the softer the tyre, the higher the probability of getting it damaged even with low impact.
pls go for something reasonable strong.
for further info yo may call: umar yaseen 0300-7636863
brother,
softness should be checked from sidewall. a tire that has a reasonable stronger structure is best suitable for Pakistan. i can tell you from my experience the lighter tires have the highest defect ratio.
imran
Only go for general tyre size 155.80.13, its excellent for cultus. And buy A grade tyre only. All imported tyres available in Pakistan are B grade tyres.
Car manufacturers use cheapest possible tyre. 155 width is too small to stop a car at high speed. 99% cultus use 17570r13.
People short on budget may use 1558013.
Generat stock tyres 155/80 in cultus are worst tyres when u will apply braking above 80 speed car steering shaking & loose grip so better to use 175/ for best combination of road grip, handling & braking..
general xp 2000II, tyres have t, rate speed with mud and snow grip signature, thats why their road grip is very good.
Got GoodYear tyres for my cultus 175/70 R13.... ride seems very much comfortable... will check further how they perform.
175/70R13 is causing space issue in Spare tyre under my cng cylinder
try Japanese spare tire
Yes, I think by Japanese u r referring to keep 1 piece of tyre of 155/80R13 as spare wheel while 4 pieces of 175/70 Has anyone tried trick to keep 175/70 R13 by using customized mounting bracket for cng cylinder..If yes kindly share pictures to give me idea
visit:
