I can tell you one part - most probably the variator stuck and grabbed, it can happen and will correct itself, remember that the variator pressure in a transmission can reach incredible level.
You are perfectly OK - dont worry, its a machine, if its output is normal now, then keep on driving. This also was a problem on the mitsu lancer CVT (pita trans)
